关于bq34z100电池匹配的问题
Other Parts Discussed in Thread: BQ34Z100
Use the bqChem feature in the Evaluation Software to select and program the chemical ID matching your cell. If
no match is found, use the procedure defined in TI's Mathcad Chemistry Selection Tool (SLUC138)..
这句话的意思是匹配电池吗?bq34z100用作镍氢电池电量检测,用 Evaluation Software 能匹配成功吗?
