Part Number: MKST-3P-ALT-EV2300
Other Parts Discussed in Thread: EV2400
大疆无人机电池激活 解锁教程
大疆无人机电池激活 解锁教程
您好,MKST-3P-ALT-EV2300相关资料在下面链接
如果要在设计期间获得支持,请联系 MKS Technology Inc.
您好,The EV2300 may not work on 64 bit Windows. This is a known issue. The EV2300 design would need to be changed to fix this issue. The components to build the EV2300 are obsolete, therefore TI is unable to make the necessary changes and instead replaced it with EV2400. Check the following threads for suggestions. Hopefully one of the suggestions work.
非常抱歉没有找到大疆电池解锁激活教程。正常情况下解锁需要知道密码。
