Part Number: TPSI3050
Hello!
I want to choose a solid-state relay to be used as a switch in the circuit. Requirements: the voltage at both ends of the switch is 1300V AC 85khz when it is disconnected, and the current passing through when the switch is closed is 10A AC 85khz. Can you recommend a relay model?
