Part Number: LM3488
Hi Team,
May I know if the maximum duty of LM3488 can be exactly 100%?
From spec, it shows 100%. And it clarifies a relationship between duty and current sense pin voltage. Is CS pin voltage literally meaning peak voltage?
Part Number: LM3488
Hi Team,
Hi
最大duty是100%, 电流限制和duty是有关的,你可以参照datasheet 第22页的计算。
