Part Number: BQ76952
Hi Ti Expert:
我们对使用了952的板子进行静测试时出现了损坏。
使用非接触式 ±15KV 打板子CAN通讯口,952第8、9、10节采样损坏。总共打了8块,全部是一样的现象。
您好,请参考下面的内容:
Is the testing being done with battery cells connected to the board? I didn't see an answer to this in your response. Are any of the components on the board damaged?
I do see some issues in the schematic, although these may not be related to the ESD test failing:
您好,非常抱歉,只有论坛支持,您的问题已经在E2E英文论坛发帖,您可以持续关注该帖。
