Part Number: BQ34Z100
我们想通过库仑计的电芯健康值来进行电芯的深度均衡,以及作为对电芯失效等判断的依据,请问,这颗库仑计是如何计算电池健康值的?从那些维度进行评估?权重如何?
您好,BQ34Z100-G1 的SOH State of health()命令使用健康负载状态来计算SOH百分比(在其他变量中)
SOH is calculated as (Full Charge Capacity) / Design Capacity. So as the Full Charge Capacity is updated as the battery ages, the SOH will decrease.
Since Design Capacity is a data flash parameter, you can try to increase this to see if you can control the SOH that way.
