Part Number: TPS65131
Dears,
Customer found that TPS65131RGER no output,they use about 100PCS,then found 30PCS failured.Remove the failure device and change the good device,then fuction is good.Below shows the schematic(designed by singapore ),pls help to check if any problems.
