Part Number: TPS92391
1. Under the condition that the output of this IC is 460mA/26.1V and the input is 8.5V, can this IC be normally applied under this condition? What is the efficiency of IC at 8.5V input?
2. How to select the voltage for UVLO undervoltage protection? For example, my input voltage is 9V, and how much should I set ULVO?
