Other Parts Discussed in Thread: BQ76952
只有SMB, 没有I2C通信选项,I2C detect一直检测不到,但是通用调试工具可以
您好,默认是I2C通讯,Serial bus communication through I2C (supporting speeds up to 400 kHz), SPI or HDQ is available, with the serial bus configured for I2C by default in the BQ76952
请参考评估板的连接方式。
