TPS73250-EP: API test Order report Error: ERR-TICOM-ORDER-API-GEN-0500
Part Number: TPS73250-EP
dear,
I am use API test place order display errorCode":"ERR-TICOM-ORDER-API-GEN-0500","type":"Application","section":"Orders","field":null,"reason":"We encountered a technical issue in processing your request.","message":"The API is temporarily unavailable. Please retry, if the issue persists, Please contact TI customer support - support.ti.com/csm","data":null}]}
In  the checkout profiles setting, the payment method selection Apruve is normal, and changed to Bank transfer shows an error!
