The article express the CCM and DCM is:
.Discontinuous inductor current mode. when the
instantaneous ampere-turns (totaled in all windings)
dwell at zero for a portion of each switching
period.
.Continuous inductor current mode. in which the
total ampere-turns do not dwell at zero (although
the current may pass through zero).
Question: the differences between the "the ampere-turns is do not dwell at zero" and "the inductor current do not dwell at zero".What is the substantial between the Dcm and Ccm.
wait for your answer.
