Other Parts Discussed in Thread: TPS61199, TPS61175
How to set the TPS61199 COMP pin? the datasheet said to refer the note SLVA492 "compensating the current mode boost converter ",but i can't find the note
many thanks
Hi Rong,
The note is SLVA452, not SLVA492. Sorry to tell that the application note is not finished yet. We suggest that you
could use the recommended compensation values in the datasheet and on the EVM. or you can set the COMP pin
refer to TPS61175 datasheet.
