BQ40Z50: BQ40Z50
Part Number: BQ40Z50
Other Parts Discussed in Thread: BQSTUDIO
BQ40Z50烧入R5的固件出现这个窗口会有问题吗?这个窗口代表什么意思?BQ40Z50-R5的固件可以使用先前的硬件芯片吗?
  • 您好,正在查询,稍后回复。
  • 您好,请参考下面内容
    This is normal and does not impact the functionality of BQStudio or the gauge.
    With the BQ40Z50-R5 firmware release we have added in extra functionality which allows you to hover over the bits and registers within BQStudio to see the TRM definition. When we push the new BQStudio test version within the next couple months the popup window you see will go away.
    Sincerely,
x 出现错误。请重试或与管理员联系。
