BQ27Z746: BqKeyPackager SHA256
Part Number: BQ27Z746
Other Parts Discussed in Thread: BQKEYPACKAGER
Hi, TI experts,
There is a confusing pop window when I generate bqk files, and the steps are as follow:
1.Choose "SHA256 Key bq9035"
2.Choose "Chanllenge(20~32bytes/40~64 hex)" and then enter SHA256 Chanllenge 1 and  Chanllenge 2
3.Choose “Key(32 bytes/64 hex)” and then enter Authentication Key
4.Enter password and comment
5.Rechoose "Chanllenge(20~32bytes/40~64 hex)"
And then click “Create bqKey File”, there will be the pop windows like this:
I think the “0x0303030303030303030303030303030303030303030303030303030303030303” will be the HMAC SHA256 Key.
The question is:
(1) What's the “Generated SHA256 Key” stands for? Will this Key affects the authentication process?
(2) When can the bqKeyPackager with bq9037 option release? (refer to https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1199589/bq27z746-bq27z746-the-hmac-sha256-keys/4527142?focus=true#4527142) Because I need it urgently, can you please share one to this account in advance?
Waiting for your reply.
Thanks!
  • 您好,
    1. The final key consists of 2 parts - Customerkey and Factorykey. The challenge is used to create a digest. This digest is displayed in the message
    2. bq9035 and bq9037 use the same type of authentication, so you can select bq9035 to package the key for bq9037
  • Some more questions,
    (1) So the message show in the pop windows "0x72CD6E8422C407FB6D098690F113087D75877BB41D39385FB8455CE60ECD8DDA" is the Factorykey?
    (2) The final key is  0x030303030303030303030303030303030303030303030303030303030303030372CD6E8422C407FB6D098690F113087D75877BB41D39385FB8455CE60ECD8DDA ?
    Is my understanding correct? Just little confused, can you explain more detail ?
    Thanks!
  • 您好,The 2 keys are combined using an algorithm and stored. The value that is stored is shown on screen.
