Other Parts Discussed in Thread: BQSTUDIO
上位机都能通信读写,指令操作尝试不行,不知道那些操作不对,求指正。
尝试给dataflash地址0x4010写入5000mv(0x1388),手写的是我计算和发送逻辑,发送完也不见更改参数,求大佬指正一下!
您好,请参考下面帖子的内容,希望对您有帮助。
您好,请确认是不是在保护状态,保护状态无法修改参数。请将Auto Refresh关掉,If this is enabled (green background), as it is in your screenshot, then bqStudio will periodically poll the gauge, which can interfere with the state of the data memory comms engine, leading to unexpected results when you try to access data memory using the advanced comms tab.
您好,请参考下面文档和帖子的内容
e2e.ti.com/.../bq34110-data-flash-writing-not-appearing-to-work
