利用BQ4050EVM-561板子,充电直到满电时,LED1-LED4都是常亮了,但LED5还是闪烁,而不是常亮,这是什么原因?
充满电时,【VCT】、[FC]、[TC]、[TAPER]四个标志位都=1了,但dashBoard看板上的电流计还有17mA电流。
您好,请参考下面帖子的内容,更您的问题类似。e2e.ti.com/.../4421111
您好,As long as the conditions are met for the gauge to be in charge mode the LED will continue to flash as mentioned in the TRM when LEDCHG is set. Charge mode is determined by your Chg Current Threshold and Quit Current.
