TPS62816-Q1: TPS61816 input current with offset and pulse frequency is about 1kHz
Part Number: TPS62816-Q1
Use the current probe to monitor Vin input current, there is DC offset and pulse(switching frequency is 2.23MHz). Is it reasonable for offset here,? And current pulse frequency is about 1kHz, is it reasonable? Or is there some problem for TPS62816 itself? Thanks for support!
