使用UCD3138 ADC14采集片内温度得到的值后,怎么转换成温度值,找半天文档没发现
你要找的是这个吗?
In order to activate the internal temperature sensor the following bit in TEMPSENCTRL register at Miscellaneous Analog Control section need to be cleared.
MiscAnalogRegs.TEMPSENCTRL.bit.TEMP_SENSE_DIS = 0;
