Hello, I now want to configure the TPS25750 through the external MCU The .c file generated by the TPS25750GUI, I don't understand the process provided by the TPS25750 Host Interface Technical Reference Manual, is there a .c file about the process? I also tried to write this process, but in the end pbmc, I read data1 and it never went to '0'. Is there a complete routine for that?
HI
我这边只有只有POE, PD硬件上电路,对于MCU的程序控制,没有相关的信息资料,建议你在美国E2E上问一下: https://e2e.ti.com/
