Other Parts Discussed in Thread: BQ79616
你好,这是BQ79616数据手册上的两个电流参数,请问这两个电流分别指的是哪儿的电流?有什么区别?数据手册上的定义没看太懂,谢谢。
您好,The IVC_DELTA value indicates the maximum delta between any 2 channels on a single device. The IVC value means the maximum input current on each VC pin across all devices
