The sense input allows the regulation circuit to compensate for voltage drop between the module and the load.
For optimal voltage accuracy –Sense must be connected to GND (pin4) very close to the module (within 10cm).
What is the reason for this distance of 10 cm
My sense is too far away and seems to cause output pulsation. Must there be a distance limit? What's the reason?
