UCD9081: UCD9081 programming
Part Number: UCD9081
1.udc90xxx_fireware_dmp.pl  ucd90xxx_dataflash_dpm.pl   Does ucd9081 support programming using these two pl files?
2.Minerva 3 PWR Sequencer Mar16 2023.par    U63_UCD_SEQUENCER_MINERVA_3.hex     How to convert ".par" and ".hex"  to xml format file?
3.Does UCD9081 support command line exe pl to programming?
4.Can you support programming hex files?
