TPS65994AE: Fast Charge Source Path
Part Number: TPS65994AE
Other Parts Discussed in Thread: TPS65988
Dear sir
Comparing TPS65994 and TPS65988, we found that the PP_HV of TPS65988 supports up to 20V, but the PP5V of TPS65994 only supports up to 5V. If TPS65994 needs to design SOURCE and support 5V, 9V, 15V, 20V Fourth gear  Fast  Charging voltage, how should the power path be designed?
x 出现错误。请重试或与管理员联系。
