Hi Team,
关于28Z610 SHA-1 加密
- 28Z610 能通过修改FW支持 SHA-2 加密吗?
- SHA-1 加密在行业的使用情况,破解难度是怎样?
- Gauge IC SHA-1 加密在行业的使用情况,破解难度是怎样?
- 听说有些厂家用你们订制Gauge IC,订制Gauge IC 在保密这块有什么加强?
Thank.
Anderson
Hi Team,
关于28Z610 SHA-1 加密
Thank.
Anderson
您好,已经在E2E英文论坛发帖,请继续关注。
您好,请参考下面内容
No the BQ28Z610 does not support SHA-2.
With the transmission rate of our gauges and using the methods available today it would take an extremely long time before you can get a collision to find the key, most likely in the millions of years. I would say the bigger risk is how the key is handled and who is given access to the key.
SHA-1 is a common authentication scheme and has been used for many years.
The SHA-1 calculation engine and commands are similar for all the gauges.
