Other Parts Discussed in Thread: TPS3897
With TLV803EB, we measured some results as the following figure (step response). The first delay is more than 90us. For that, we want to know the start-up delay.
If we refer to other datasheet, for example TPS3897, we can know the startup delay parameter. It will explain why the first delay is more than 90us under step response. Could you provide similar parameter for TLV803EB?
Thanks for you answer
