BQ76940: 针对23S应用,推荐的电池配置是什么?
Part Number: BQ76940
方案1、L 930(10S)+H 940(13S)
方案2、L 940(11S)+H 940(12S)
方案3、L 940(12S)+H 940(11S)
希望兼容20S-24S
其他方案:L 940 + H 930
  • 您好,Although there technically isn't a limit, we typically recommend limiting this to two AFEs in series. Stacking is not an integrated feature, so more careful considerations must be taken.
    If you want to have more stacked, we often recommend using the automotive-rated parts as these have stacking interfaces integrated into them.  Like the BQ796916-Q1.
