Part Number: BQ27426
We need to use the external temperature Sensor function of the fuel meter. The device has a built-in battery and does not need the battery insertion and extraction detection function. How should the BIN pin of the chip be handled? Does it need to be connected to a 1.8M pull-up resistor? Or can it be directly connected to the thermistor of the battery?
