Dear TI support team,
I have a project which use TPS25762 for PD charging.
- In order to get the availableoutputs of the chip,i use PD trigger as load,but only 5V and 9V is stable,other higher voltage request causes outputs jumping.
- Additionally,I have another try.i connect TPS25762 to notebook which supports PD charge with standard TypeC cable. then i use the oscilloscope to capture the wave of the TPS25762's output.
- Configuration keys files and base firmware areget from TI E2E teams.
- I have uploaded my schematic diagram, Vbus output pictures,PD triggerinformation and Configuration files
Pls help to double check my design and analyse why PD Vbus can’t output 12V/15V and so on.
Thank you in advance!
