Other Parts Discussed in Thread: TPS2H160-Q1,
您好,在 TPS2H160-Q1的规格书中有如下描述,为确保可靠性和性能,焊接覆盖率应至少达到85%(To ensure reliability and performance, the solder coverage should be at least 85%.),这一数据是如何计算或仿真得出的?
TPS2HB16-Q1 DRV8718 DRV8705是否也有类似的数据可供参考?
