Other Parts Discussed in Thread: BQ79616
我计划用BQ79616代替现有项目的AFE,但不知道BQ79616是否支持直接连接外部主动均衡电路
您好,可以将平衡功能disable,If you connect the CB pins to the batteries, they will not cell balance on their own. They will only begin balancing if the MCU sends a certain command. So, you can connect the CB pins normally and get the functionality you want. Additionally, the CB pins are used for redundant ADC measurement, so it is a good idea to connect them.
