Other Parts Discussed in Thread: BQEVSW, BQSTUDIO, BQ27741EVM
各位 :
我已經借由 battery management studio 配置完成 , 並且得到了 .srec bq.fs df.fs 三個檔案 ,
請問df.fs該文件是否為量產文件 ?
我又該如何借由 battery management studio 配置成 HDQ 模式 ?
各位 :
請問df.fs該文件是否為量產文件 ?
你好,目前手头只找到该器件基于BQEVSW BQeasy软件进行量产的步骤和指导信息 ,请参考如下链接。
http://www.ti.com.cn/general/cn/docs/lit/getliterature.tsp?baseLiteratureNumber=slua504&fileType=pdf
这个BQstudio还比较新,一些相关的支持文档还没有同步公开,请参考与之类似器件的 基于BQstudio的指导文档
见如下链接中 User Guides (2) bq27741EVM Single-Cell Impedance Track™ Technology Evaluation Module 。
http://www.ti.com/tool/bq27741evm
其中的section 11提到如何找转换HDQ的界面
11 Send HDQ Screen
To configure a bq27741 into HDQ mode, navigate to the Send HDQ screen. It is possible that all the
screen options on the left are not visible depending on screen resolution. If needed scroll within the left
menu to access the Send HDQ link. Click on the "Change comm to HDQ8" button while having the
bq27741 connected to the EV2300 via I2C. Clicking on the button causes a message to appear indicating
that the process is not reversible and to confirm if the actions are desired. Also, it explains what to do
once the HDQ mode has been activated.
Once converting the bq27741 into HDQ mode, it is required that you connect the HDQ terminal of the
EV2300 with the HDQ connector (J4) of the bq27741 EVM, then restart the EVSW, and select the
"bq27741HDQR1" with the proper firmware version from the list of supported devices within the EVSW.
