Part Number: BQ76952
BQ76952 Manual control,Partially autonomous,Fully autonomous 具体需要配置哪些寄存器,因为我们发现有时FET不受主机控制,自己关闭了,当检查到充电MOS自己关闭后,程序中会再次打开充电MOS,导致充电MOS来回跳动,我怀疑是不是我这几个模式没有配置好导致的
See the section below taken from Section 5.2.3.2 of the TRM.
To configure the device to only turn on/off the FETs using commands from the host processor, then:
