您好,配置不对学习可能会无法成功。CHEM ID 请使用GPDDCHEM tool 帮助计算。
https://www.ti.com.cn/tool/cn/GPCCHEM?keyMatch=&tisearch=search-everything&usecase=software
您好,请参考下面文档学习。
https://www.ti.com/lit/an/slva725a/slva725a.pdf?ts=1696830867432
BQstudio使用请参考评估板的用户手册3.1 寄存器屏幕。
您好,选program selected chemistry,program from GPCRB file是配置GPCRB tool低温补偿参数用的。
非常感谢!有回复了麻烦尽快通知我一下。
现在有个新问题,现在TI邮箱一直给我发下如下错误,请问是什么问题?
We were not able to submit a power calculator request to MQ. MQ notifies the program of the failure, by returning a completion code (MQCC), and a reason code (MQRC). The following is a code returned by MQ : MQCONN ended with reason code 2538 |
你好!工具还是不行哦,邮件回复如下:Thank you for your interest in the Gauging Parameter Calculator from TI.
There was an error in processing your report. The specific error encountered is:
There was a problem with the content of the zip file.
