LMG3522R030-Q1: spice model from TI can’t be used in LTspice
Part Number: LMG3522R030-Q1
When I first started using the model, the issue with the curly braces in the lib file would report an error and LTspice would show that it could not find the definition of diode D_D1.When I removed the curly braces, the problem with the curly braces disappeared but LTspice still shows that the definition of diode D_D1 cannot be found.
I need some help to solve the problem.
