请问如图片所示检测到的设备号是哪款芯片?
您好,请参考附件内容. 请检查此目录中是否有这个文件"C:\Program Files (x86)\Texas Instruments\bq Evaluation Software"
您好,The file should not be copied. Instead, you should have the installer. You are probably missing the .ini file as well.
Please inform you to install the executable file (bqEVSWSetup00.09.77_bq20z655v0.03b.exe) which should automatically add all requirements for it to work.
If you do not have the executable file, how did you find out about this device?
您好,下面链接的文件安装试一下能不能打开。
