Other Parts Discussed in Thread: TPS54360
1. When using TPS2378 under light load (less than or equal to 11mA), 2.46S restart interval will appear, and the load greater than 11mA will be normal;
2. With load, the ground of the oscilloscope used for POE power supply contacts the PCB output ground, and there will be load failure; When no load, the oscilloscope's ground contacts the PCB's output ground, there will be a stable voltage value (can not be loaded);
