LP5036: LP5036
Part Number: LP5036
Dear Texas Instruments Technical Support Team,
I'm a customer using your LP5036 product and recently encountered an issue during the debugging process. I hope to get your help and support.
While using the LP5036, I noticed that when the input data changes from 0X7F to 0X80, the output PWM duty cycle undergoes a sudden change. I'm concerned that this might be a bug, so I'm hoping you can check and confirm if this issue exists, and provide a solution.
My configuration information is: 9Bits, linear adjustment mode.
Thank you very much for your help, and I look forward to your response.
Thanks,
Relyme.zhang
