Part Number: BQ79600EVM
请问一台电脑能连接几个BQ79600EVM ,我用FTDI 连接
我当前想连接3个
您好,You cannot use more than one BQ79600 in a stack. This will cause auto-addressing and read/write command errors because all the BQ79600 devices will have the same 00 address. This cannot be changed, and it will prevent the customer from being able to select which BQ79600 they want to read/write to.
