您好,The first rate should be average typical, and second should be average high for your application. Note that high rate should not be maximum peak current, but rather maximum average sustained rate that can practically occur in the application
详细请参考文档Simple Guide to CEDV Data Collection for Gauging Parameter Calculator (GPC)
