Other Parts Discussed in Thread: EV2400, , BQSTUDIO
BQ34Z100-G1成功连接之后在芯片的图标上有一把琐,如图所示,有时候有,有时候会消失。请问这个锁表示什么含义,是sealed?芯片保护?芯片休眠?还是EV2400与芯片通信存在错误?如何让这个锁一直有或者不再出现?
您好,Only the far right of bqstudio window, there is the command sub window that contains buttons. One of the buttons is the unseal while the other is the unseal full access. You need to click both to unseal the gauge. If you changed the password from the default, the default passwords would not work.
