您好,1,2是用评估板测试出现的问题吗?建议您用评估板做一下测试。
3,可以接GND,电路请参考BQ25756 Schematic Checklist
您好
1. Did you also set EN_TERM = 0 for the no load test?
2. Is the output prone to overshoot while a load is attached? What are you using as the load?
