I want to use the LM3410 to design a flash circuit, reference to the relevant circuits drawn PCB circuit board, but my circuit does not seem to work in the most perfect state, the brightness of the lamp does not meet my expectations, I hope that your company to help me modify the circuit, the following is my reference circuit。
Inside this circuit I used three high brightness 3535 LEDs in series, but they are not bright enough, here are the parameters of the 3535 LEDs, and the fact that I want to make sure this circuit is made small enough.
I don't know how to design this circuit to make him work in the perfect state, and to make the small light bright enough, (the small light doesn't need to be on all the time, it will be controlled by the microcontroller to blink a few times quickly at specific moments)
