您好,不会影响SOH的计算。
SOH is calculated as QMax*IR@25C. You can see the gauge calcualation at [SOHFC@25C Q] register. In this equation I = DesignCapacity/SOH Load rate (default C/5). R is from the Ra table of the gauge. This value is then divided by Design capacity to report a %.
The only thing that could really impact you would be
1) Writing Design Capacity wrong
2) QMax update very small
3) Ra update very large.
