BQ27Z746: 250mAh磷酸铁锂电池,匹配的化学ID偏差大于4%。但已经学习成功。
Part Number: BQ27Z746
Other Parts Discussed in Thread: GPCCHEM, BQ40Z50
250mAh磷酸铁锂电池,匹配的化学ID偏差大于4%。能学习成功学习后的电池容量有280mA左右,但0.2C放电到末端,SOC还有30%电量。
这样是不是要重新定制ID.
  • 您好,方便将GPCCHEM 报告和学习成功的log数据和有问题的log数据发过来看一下。
  • Chemistry ID selection tool, rev=2.54
    Configuration used in present fit:
    ProcessingType=2
    NumCellSeries=1
    ElapsedTimeColumn=0
    VoltageColumn=2
    CurrentColumn=3
    TemperatureColumn=1
    Best chemical ID : 448	Best chemical ID max. deviation, % : 7.65
    Summary of all IDs with max. DOD deviation below 15%
    Chem ID	max DOD error, %	Max R deviation, ratio
    448	7.65	1.27
    482	7.93	2.04
    400	8.29	2.77
    481	8.41	1.47
    426	8.82	1.48
    4111	9.09	0.13
    459	9.44	3.23
    6104	9.45	3.45
    4167	9.47	1.77
    405	9.76	1.02
    4130	9.83	1.5
    4159	9.85	0.61
    485	9.85	2.19
    487	9.85	2.19
    461	9.88	1.75
    4150	10.04	1.81
    4124	10.05	1.41
    406	10.07	2.14
    442	10.14	1.94
    402	10.17	1.08
    424	10.17	0.76
    486	10.23	0.91
    4151	10.3	2.21
    2160	10.32	2.16
    457	10.38	5.29
    4166	10.41	1.07
    4106	10.47	0.75
    449	10.74	0.63
    472	10.76	3.98
    4110	10.82	0.57
    4131	10.85	2.9
    6105	10.87	0.49
    414	10.92	1.35
    4153	11.17	0.55
    4164	11.28	2.43
    454	11.47	0.73
    411	11.51	1.17
    4141	11.67	0.53
    429	11.69	0.69
    4173	11.74	2.82
    403	11.77	1.73
    4160	12	0.52
    4140	12.09	1.15
    4161	12.27	0.68
    496	12.33	0.59
    4139	12.36	0.65
    427	12.57	0.67
    451	12.69	2.04
    488	12.72	0.62
    6106	12.75	2.43
    445	12.77	1.62
    4134	12.82	1.12
    422	12.92	0.63
    4118	12.96	2.07
    435	13	1.69
    4142	13	0.6
    6110	13.21	0.38
    447	13.24	2.96
    419	13.61	1.36
    450	13.71	1.96
    4172	13.74	2.31
    4144	13.85	2.53
    425	14.06	1.89
    491	14.22	2.6
    413	14.34	1.76
    433	14.34	1.19
    464	14.35	4.83
    416	14.36	1.35
    474	14.4	1.72
    432	14.41	0.53
    423	14.41	1.24
    4157	14.45	1.55
    437	14.68	2.07
    4138	14.73	1.94
    436	14.8	2.76
    4168	14.83	1.38
    453	14.94	0.03
    412	14.99	3.08
    Max. deviations for best ID is within recommended range. Chosen best chemical ID is suitable for programming the gauge.
    Selection of best generic ID for ROM based devices like bq274xx
    Device / Family #1
    Generic Chem ID	Device/ Voltage/ Chemistry	max DOD error, %
    312	bq27421-G1B: 4.3V LiCoO2	26.54
    354	bq27411-G1C: 4.35V LiCoO2	37.43
    3142	bq27421-G1D: 4.4V LiCoO2	43.35
    128	bq27421-G1A: 4.2V LiCoO2	52.48
    Best generic ID 312
    Warning: Generic ID Deviation is so high that it is most likely due to anomaly in the data. Please check that data files have recomended format, units and test schedule
    Device / Family #2
    354	bq27621:  (ALT_CHEM2) 4.35V LiCoO2	37.43
    1202	bq27621: (default) 4.2V LiCoO2	37.84
    1210	bq27621:  (ALT_CHEM1) 4.3V LiCoO2	41.19
    Best generic ID 354
    Device / Family #3
    3230	bq27426: (default) 4.35V LiCoO2	35.41
    1202	bq27426: (ALT_CHEM1) 4.2V LiCoO2	37.84
    3142	bq27426: (ALT-CHEM2) 4.4V LiCoO2	43.35
    Best generic ID 3230
    ProcessingType=2
    NumCellSeries=1
    ElapsedTimeColumn=0
    VoltageColumn=2
    CurrentColumn=3
    TemperatureColumn=1
    Best chemical ID : 482	Best chemical ID max. deviation, % : 8.21
    482	8.21	3.01
    400	8.24	3.25
    448	8.5	1.92
    481	8.64	1.88
    4119	8.78	0.67
    426	9	1.72
    4167	9.42	1.87
    461	9.71	1.93
    4124	9.8	1.46
    4130	9.84	1.53
    4159	9.9	0.67
    405	9.98	1
    4150	10.01	1.86
    2160	10.05	2.13
    424	10.05	0.85
    485	10.17	2.84
    487	10.17	2.84
    406	10.32	2.17
    4106	10.37	0.77
    4166	10.42	1.16
    449	10.44	0.66
    4110	10.51	0.77
    442	10.53	2.16
    4151	10.88	2.42
    4131	10.89	2.88
    414	10.93	1.72
    6105	10.95	0.62
    4164	10.99	2.47
    457	11.18	5.87
    472	11.25	3.91
    454	11.32	1.27
    402	11.41	1.18
    403	11.45	1.92
    6104	11.64	3.64
    4111	11.74	0.29
    411	11.74	1.4
    486	11.79	0.94
    4141	11.82	0.58
    429	11.93	0.74
    4153	11.95	0.52
    4173	12	2.8
    4160	12.05	0.53
    4140	12.08	1.19
    4161	12.17	0.67
    4139	12.19	0.84
    496	12.27	0.72
    4134	12.33	1.21
    459	12.36	3.3
    445	12.5	1.78
    416	12.62	1.55
    6106	12.74	2.61
    488	12.75	0.59
    422	12.78	0.63
    427	12.91	0.93
    451	13.11	2.35
    435	13.32	1.89
    415	13.6	1.17
    4118	13.74	2.08
    419	13.88	1.65
    4144	13.95	2.9
    413	14.04	1.89
    423	14.13	1.5
    425	14.23	2.13
    4157	14.26	1.65
    447	14.26	3.34
    464	14.29	2.57
    433	14.38	1.33
    491	14.39	2.94
    474	14.39	1.9
    4172	14.52	2.57
    4138	14.56	1.98
    432	14.63	0.74
    4168	14.77	1.61
    4171	14.87	2.4
    437	14.93	2.65
    4149	14.93	0.5
    Device / Family #1
    312	bq27421-G1B: 4.3V LiCoO2	24.21
    354	bq27411-G1C: 4.35V LiCoO2	37.42
    3142	bq27421-G1D: 4.4V LiCoO2	43.42
    128	bq27421-G1A: 4.2V LiCoO2	51.14
    Best generic ID 312
    Device / Family #2
    354	bq27621:  (ALT_CHEM2) 4.35V LiCoO2	37.42
    1210	bq27621:  (ALT_CHEM1) 4.3V LiCoO2	41.28
    Best generic ID 354
    Device / Family #3
    3230	bq27426: (default) 4.35V LiCoO2	35.29
    3142	bq27426: (ALT-CHEM2) 4.4V LiCoO2	43.42
    BQ27Z746-M11390L1-1S1P_ID481-250mAh-3.65V-20240115-A0-Learning.logBQ27Z746-M11390L1-1S1P_ID481-250mAh-3.65V-20240115-A0 SOC test.log
    ProcessingType=2
    NumCellSeries=1
    ElapsedTimeColumn=0
    VoltageColumn=2
    CurrentColumn=3
    TemperatureColumn=1
    Best chemical ID : 482	Best chemical ID max. deviation, % : 4.12
    482	4.12	2.27
    481	4.56	1.3
    448	5.53	1.49
    4111	5.55	0.16
    6105	7.11	0.71
    459	7.17	3.67
    6104	7.21	3.89
    2160	7.34	1.98
    4172	7.42	2.45
    4153	7.45	0.5
    471	7.49	1.34
    437	7.55	1.92
    487	7.58	2.43
    485	7.58	2.43
    4110	7.74	0.48
    405	8.02	1.13
    4167	8.13	1.59
    483	8.19	0.53
    4150	8.22	1.76
    446	8.4	0.19
    400	8.52	2.54
    466	8.54	0.59
    453	8.69	0.01
    451	8.7	2.13
    457	8.71	5.49
    4130	8.81	1.38
    424	8.88	0.79
    465	8.96	1.85
    426	8.97	1.47
    438	8.98	3.41
    4159	9.35	0.72
    411	9.37	0.91
    4124	9.59	1.35
    402	9.61	1.07
    406	9.61	1.91
    442	9.61	1.86
    486	9.65	0.81
    4160	9.69	0.52
    4166	9.71	0.9
    414	9.73	1.48
    429	9.77	0.65
    449	9.84	0.66
    4173	9.87	2.77
    4106	9.95	0.74
    443	9.97	1.94
    461	10.01	1.9
    447	10.17	3.08
    4142	10.19	0.63
    427	10.32	0.53
    4151	10.37	1.97
    419	10.44	1.34
    4140	10.47	1.11
    4164	10.57	2.23
    4131	10.77	2.17
    472	10.78	3.39
    474	10.89	1.82
    454	10.99	0.9
    488	11.03	0.63
    479	11.28	0.83
    416	11.42	1.24
    403	11.43	1.59
    435	11.48	1.29
    4141	11.48	0.45
    496	11.6	0.59
    4144	11.64	2.56
    4139	11.72	0.69
    450	11.88	1.89
    4168	11.99	1.32
    491	12.17	2.61
    445	12.18	1.7
    423	12.25	1.37
    4161	12.28	0.66
    464	12.31	4.19
    6106	12.41	2.24
    4134	12.43	0.98
    440	12.43	0.51
    420	12.44	0.58
    425	12.49	2.06
    418	12.67	0.7
    422	12.7	0.6
    6110	12.84	0.46
    4118	12.98	2
    4157	12.99	1.5
    432	13.26	0.6
    4135	13.28	0.41
    433	13.39	1.1
    413	13.57	1.63
    436	13.59	2.29
    431	13.66	0.99
    430	13.75	0.63
    462	14.07	4.77
    407	14.16	0.91
    4109	14.65	1.06
    412	14.73	3.1
    460	14.79	1.2
    4138	14.83	1.72
    4170	14.9	3.04
    Device / Family #1
    312	bq27421-G1B: 4.3V LiCoO2	22.79
    354	bq27411-G1C: 4.35V LiCoO2	37.13
    128	bq27421-G1A: 4.2V LiCoO2	52.03
    Best generic ID 312
    Device / Family #2
    354	bq27621:  (ALT_CHEM2) 4.35V LiCoO2	37.13
    1202	bq27621: (default) 4.2V LiCoO2	37.53
    1210	bq27621:  (ALT_CHEM1) 4.3V LiCoO2	40.92
    Best generic ID 354
    Device / Family #3
    1202	bq27426: (ALT_CHEM1) 4.2V LiCoO2	37.53
    您好,以上是GPCCHEM 报告和学习成功的log数据和有问题的log数据。
    另外有广东地区的FAE的联系方式吗。公司这个项目马上开始进入样品阶段,自制的电芯方案确定想定制专用的的ID。
    以前三元电芯做笔电,用的是BQ40Z50 R3 GPCCHEM 报告中匹配的ID中最大错误基本都是0.8%以下。学习也都是100%成功,量产都没有问题。
  • BQ27Z746-M11390L1-1S1P_ID481-250mAh-3.65V-The SOC is correct after changing Term Voltage from 2.55V to 2.7V.log
    您好:将Term Voltage","2550","mV"从2.55V更改为2.7V后,SOC才正确显示。
    以上是最新的LOGO数据。
  • 您好,三分报告中有一个报告推荐使用Best chemical ID : 482就可以,应该不需要专门定制ID
