Other Parts Discussed in Thread: BQSTUDIO
1.I have encountered some problems, the manual says that you should use little endian write command, but the configuration given in the manual section 7.1 is big endian, which one should I use?
2.Do I need to use the bigendian and little endian order depending on the condition?
