Part Number: BQ24610
Dears,
issue description,
The HIDRV and LODRV output have failed in charge process, normal is PWM waveform, failed waveform is pulses with a period of 4ms, the STAT1 STAT2 PG is normal voltage.
HIDRV output
BTST voltage
Dears,
issue description,
HIDRV output
BTST voltage
