如何关闭BQ25892的 battery monitor。在battery only mode下,当我的设备处于关机状态时25892的功耗有点高,发现是由于25892的monitor处于开启状态。
您好,The battery monitor refers to the ADC function. There is a section describing this function called "Section 9.2.8 Battery Monitor" on page 28 of the datasheet. The ADC feature is disabled by default. The relevant register is REG02 bits 7 and 6.
HIZ mode is enabled/disabled in REG00 bit 7.
