Hello, expert:
Regarding the recovery logic issue of the wheel speed interface overcurrent fault, we have followed the steps described in the document, but the OC flag in 0x0f is not clear. Can you provide guidance?
Hello, expert:
Hi
按照: first disable the WSPx pins, re-enable the WSLSx pins, and finally re-enable the WSPx pins. 操作不行吗?
