HI all
We have a project for 3352+65217。We used I2C0 to connect 65217,and there is also a touchscreen device I2c on the I2c0.
The issue is that the 65217 fail sometime ,AC to SYS failed.
when we remove the touchscreen I2C from I2C0, the issue disappare.
Could you explain how the I2C affect the 65217 performance
Thank you very much!
