学习过程中如配置文件配置,静置6小时后打算进入下一部时却直接跳到了放电状态,错过了充电和静置,而且开始学习的界面在运转,但是查看Update Status为什么还是00?看手册不是应该会有变化的吗?
想知道他为什么我插上充电器准备进入充电界面时,就往下跳到放电学习块了,他是如何判断我目前是在充电还是在放电的学习块。以及为什么Data Memory 界面中Update Status一直是00,没有类似手册上的变化。
Configuration | Safety | Over Temp | 55 | °C |
Configuration | Safety | Under Temp | 0 | °C |
Configuration | Safety | Temp Hys | 5 | °C |
Configuration | Charge Termination | TCA Set % | 99 | % |
Configuration | Charge Termination | TCA Clear % | 95 | % |
Configuration | Charge Termination | FC Set % | -1 | % |
Configuration | Charge Termination | FC Clear % | 98 | % |
Configuration | Charge Termination | DODatEOC Delta T | 5 | °C |
Configuration | Data | Design Voltage | 3600 | mV |
Configuration | Data | Initial Standby | -3 | mA |
Configuration | Data | Initial MaxLoad | -200 | mA |
Configuration | Discharge | SOC1 Set Threshold | 10 | % |
Configuration | Discharge | SOC1 Clear Threshold | 15 | % |
Configuration | Discharge | SOCF Set Threshold | 2 | % |
Configuration | Discharge | SOCF Clear Threshold | 5 | % |
Configuration | Registers | OpConfig | 25f8 | Flag |
Configuration | Registers | OpConfigB | 0f | Flag |
Configuration | Power | Hibernate I | 3 | mA |
Configuration | Power | Hibernate V | 2200 | mV |
Gas Gauging | IT Cfg | FH Setting 0 | 60 | s |
Gas Gauging | IT Cfg | Ra Filter | 800 | Num |
Gas Gauging | IT Cfg | FH Setting 1 | 100 | s |
Gas Gauging | IT Cfg | FH Setting 2 | 18000 | s |
Gas Gauging | IT Cfg | FH Setting 3 | 25 | s |
Gas Gauging | IT Cfg | Fast Qmax Start DOD % | 92 | % |
Gas Gauging | IT Cfg | Fast Qmax End DOD % | 96 | % |
Gas Gauging | IT Cfg | Fast Qmax Start Volt Delta | 125 | mV |
Gas Gauging | IT Cfg | Fast Qmax Current Threshold | 4 | Hr rate |
Gas Gauging | IT Cfg | Fast Qmax Min Points | 3 | Num |
Gas Gauging | IT Cfg | Max Qmax Change | 20 | % |
Gas Gauging | IT Cfg | Qmax Max Delta % | 10 | %DCap |
Gas Gauging | IT Cfg | Max % Default Qmax | 120 | %DCap |
Gas Gauging | IT Cfg | Qmax Filter | 96 | Num |
Gas Gauging | IT Cfg | ResRelax Time | 500 | s |
Gas Gauging | IT Cfg | User Rate-mA | 0 | mA |
Gas Gauging | IT Cfg | User Rate-mW | 0 | mW |
Gas Gauging | IT Cfg | Max Sim Rate | 1 | Hr rate |
Gas Gauging | IT Cfg | Min Sim Rate | 20 | Hr rate |
Gas Gauging | IT Cfg | Ra Max Delta | 11 | 4mOhm |
Gas Gauging | IT Cfg | Min Delta Voltage | 0 | mV |
Gas Gauging | IT Cfg | Max Delta Voltage | 200 | mV |
Gas Gauging | IT Cfg | DeltaV Max dV | 100 | mV |
Gas Gauging | IT Cfg | TermV Valid t | 2 | s |
Gas Gauging | Current Thresholds | Dsg Current Threshold | 167 | .1 Hr rate |
Gas Gauging | Current Thresholds | Chg Current Threshold | 100 | .1 Hr rate |
Gas Gauging | Current Thresholds | Quit Current | 25 | .1 Hr rate |
Gas Gauging | Current Thresholds | Dsg Relax Time | 600 | s |
Gas Gauging | Current Thresholds | Chg Relax Time | 60 | s |
Gas Gauging | Current Thresholds | Quit Relax Time | 1 | s |
Gas Gauging | Current Thresholds | Max IR Correct | 400 | mV |
Gas Gauging | State | Qmax Cell 0 | 16384 | Num |
Gas Gauging | State | Update Status | 0 | Hex |
Gas Gauging | State | Reserve Cap-mAh | 0 | mAh |
Gas Gauging | State | Load Select/Mode | 81 | Hex |
Gas Gauging | State | Q Invalid MaxV | 3803 | mV |
Gas Gauging | State | Q Invalid MinV | 3752 | mV |
Gas Gauging | State | Design Capacity | 4000 | mAh |
Gas Gauging | State | Design Energy | 14800 | mWh |
Gas Gauging | State | Terminate Voltage | 3000 | mV |
Gas Gauging | State | T Rise | 20 | Num |
Gas Gauging | State | T Time Constant | 1000 | s |
Gas Gauging | State | SOCI Delta | 1 | % |
Gas Gauging | State | Taper Rate | 100 | .1 Hr rate |
Gas Gauging | State | Taper Voltage | 4100 | mV |
Gas Gauging | State | Sleep Current | 10 | mA |
Gas Gauging | State | V at Chg Term | 4190 | mV |
Gas Gauging | State | Avg I Last Run | -50 | .1 Hr rate |
Gas Gauging | State | Avg P Last Run | -50 | .1 Hr rate |
Gas Gauging | State | Delta Voltage | 1 | mV |
Ra Tables | R_a RAM | R_a0 0 | 102 | Num |
Ra Tables | R_a RAM | R_a0 1 | 102 | Num |
Ra Tables | R_a RAM | R_a0 2 | 99 | Num |
Ra Tables | R_a RAM | R_a0 3 | 107 | Num |
Ra Tables | R_a RAM | R_a0 4 | 72 | Num |
Ra Tables | R_a RAM | R_a0 5 | 59 | Num |
Ra Tables | R_a RAM | R_a0 6 | 62 | Num |
Ra Tables | R_a RAM | R_a0 7 | 63 | Num |
Ra Tables | R_a RAM | R_a0 8 | 53 | Num |
Ra Tables | R_a RAM | R_a0 9 | 47 | Num |
Ra Tables | R_a RAM | R_a0 10 | 60 | Num |
Ra Tables | R_a RAM | R_a0 11 | 70 | Num |
Ra Tables | R_a RAM | R_a0 12 | 140 | Num |
Ra Tables | R_a RAM | R_a0 13 | 369 | Num |
Ra Tables | R_a RAM | R_a0 14 | 588 | Num |
Calibration | Data | Board Offset | 0 | Counts |
Calibration | Data | Int Temp Offset | 0 | °C |
Calibration | Data | Pack V Offset | 0 | mV |
Calibration | CC Cal | CC Offset | 2 | Counts |
Calibration | CC Cal | CC Cal Temp | 303 | °K |
Calibration | CC Cal | CC Gain | 0.2379 | Num |
Calibration | CC Cal | CC Delta | 283770.3125 | Num |
Calibration | Current | Deadband | 5 | mA |
Security | Codes | Sealed to Unsealed | 80008000 | Hex |
